Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
VHT 550°F Engine Enamel Gloss Clear
Be the first to review this product
You could receive 100 Caswell Gold Rewards Points for writing a review and/or rating this product.
$7.70
Use Your Points:
You will earn 7 Caswell Gold Rewards Points for buying this product
OR
Quick Overview
SKU: SP-145
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Applications:
  • Engines
  • Alternators
  • Water Pumps
  • Transmissions
  • Heads
  • Engine Blocks
  • Differential Covers
  • Brackets
  • Starters
  • Oil Pans
  • Valve Covers
  • Drive Trains
  • Painted Engine Components
VHT 550F (288C) Engine Enamels are available in a wide range of colors, including exact match factory colors. All colors have excellent durability and superior heat and solvent resistance. They are specially formulated to withstand corrosion, rust, salt spray, strong solvents and additives of today's gasoline blends and degreasers. VHT 550F (288C) Engine Enamels are a unique blend of urethane resins, which produce a tough and long-lasting finish for engines, engine accessories or wherever a tough durable heat or chemical resistant finish is needed.
Dry Time
Dries to the touch in 15 to 30 minutes, Thoroughly overnite. Curing time required and can be done on or off the vehicle
How-To
1. Use VHT Aggressive Strip Fast Paint Remover (SP-575) to remove all dirt, rust, scale and paint. This can also be accomplished by sand blasting. Finally, clean with non-residue solvent and allow to dry before spraying
2. Mask areas not to be sprayed. Also protect surrounding area from overspray.
3. For best results, apply when parts, can, and ambient temperature is between 70F (21C) and 90F (35C).
4. Shake can vigorously for one minute after mixing ball rattles. Shake periodically between coats.
5. Spray object with can upright about 15 inches from the object. More thin coats are better than fewer thick coats. Apply all coats within 30minutes or wait 24 hours to apply successive coats. If paints sags or runs, you are to close or applying to heavily. VHT Engine Enamel will dry to the touch in 15-30 minutes. Dries completely overnight.
6. EXTREMELY IMPORTANT - After paint is completely air dried, it must be cured to substantially increase the durability of the finish and enhance chemical resistance. See curing for details.
7. Clear out sprayer after each use by turning can upside down and pressing spray button until no paint comes out.
8. If clogging develops, remove spray button with a twisting motion and clean. Do not stick pin or other objects in to can. Gently replace spray button with a twisting motion while top of can and spray button opening are pointing away from you.
Curing
Off the Vehicle:
Bake at 200F for 1 hour. Caution: Do not exceed the heat tolerance of least heat tolerant component.
On the Vehicle:
The inherent heat of engine operation will also accomplish curing. Start the engine and run at idle for 15 minutes and let cool. Restart engine and run no more than 1 hour and again let cool. Finish is not chemical resistant until cured.
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
