The active solder paint
Here's a great new way to carry out repairs to pits in your castings. Plum-Loy is made from a fine dust of solder, mixed with tinning flux and cleaning agents. It can be painted onto a surface with a small brush. As soon as the tip of a torch flame touches the thin layer of Plum-Loy, it melts, 'tinning' the surface. This uses much less heat than required to melt a stick or wire solder, making it ideal to repair onto thin plated surfaces. Dents in the surface? Simply apply Plum-Loy to the area, melt it, then apply regular stick solder to 'puddle in' the area, just like the old fashioned way of lead filling. Deep pits? Paint over a layer of Plum-Loy, heat to melt, then apply more to fill the hole. Plum-Loy is ideal for painting over those areas with small pits or scratches. It will bond to steel, copper, brass, bronze, and nickel. It can ONLY be plated with copper plate. Ideally, you should try to sandwich the Plum-Loy between two layers of copper plate. To finish:- Sand or file down the area, then apply a copper plate to cover. Buff the plate and finish with nickel and or chrome. |
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Anodizing Products (67)
Anodizing Kits (2)
Anodizing Dyes (53)
Chrome Plating Kits (53)
Nickel Plating Kits (57)
Copper Plating Kits (44)
Gold Plating Kits (19)
Gold Brush Plating (16)
Silver Plating Kits (13)
Chromates (6)
Tin Plating Kits (11)
Metal Strippers (11)
Books and Videos (6)
Plating Crystals (13)
Other Chemicals (45)
Anodes (14)
Plug N' Plate® Kits (26)
Black Oxide Kits (17)
Antiquing Solutions (15)
Buffing/Polishing (440)
Buffing Wheels (83)
Sisal Wheels (7)
Razor Buffs (3)
Scrubber Wheels (2)
Sisal Rope Buffs (1)
Mushroom Buffs (4)
Facer Buffs (3)
Cushion Buffs (3)
Tapered Buff (1)
String Buff (1)
Hourglass Buff (1)
Felt Wheels (5)
Liquid Polishes (2)
Wheel Rake (2)
Buffing Machines (14)
Buffing Adapters (21)
Shaft Extenders (8)
Bench Mandrels (2)
Buffing Kits (23)
Sanding Supplies (5)
Wet/Dry Sandpaper (14)
Abrasive Wheels (30)
Flap Wheels (9)
Cartridge Rolls (8)
Felt Bobs (17)
Diamondite® (24)
Waxes & Polishes (51)
Peek Polish (4)
ShineSeal (2)
Powder Coating (137)
Candy Top Coats (9)
Powder Coating Ovens (11)
Curing Lamps (3)
Starter Kits (2)
Masking Products (10)
Primers (8)
Restoration Aids (305)
Permatex® Products (101)
Permatex® Sealants (11)
Evercoat Products (19)
Glyptal (2)
Metal Etching (1)
Tech-Line Coatings (29)
Lab Metal® (4)
Plasti Dip (30)
Welding Products (7)
Repair Pastes (5)
Cyclone Abrasives (37)
Paints and Coatings (480)
VHT Aerosol Paints (98)
VHT Motor Brite (1)
VHT Quick Coat (13)
VHT Epoxy Paint (3)
VHT Strip Fast (1)
VHT Primecoat (6)
VHT Vinyl Dye (7)
VHT Night Shades (1)
Krylon Fusion (41)
Krylon Engine Paint (14)
Camouflage (45)
Skull Patterns (8)
Metal Patterns (8)
Animal Patterns (9)
Marble & Stone (4)
Illusion Patterns (15)
Accessories (6)
Plasti Dip (21)
RC Modeling (151)
Submarine Models (2)
Fittings Kits (10)
Electronics (13)
Torpedo Systems (9)
Model Ships (5)
Propellers (0)
Books and DVDs (6)
Gun Metal Bluing (3)
DuraCoat (33)
You have no items in your shopping cart.
You have no items to compare.
My Buff keeps flying off ...!
05.22.2012 14:05
Hi guys ... I have had wonderful luck with the CASWELL buffer I bought...
new to this thread have very little knowledge pls help me
05.22.2012 02:05
hello,i want to make an biomass(60 W) fired oven of size 4*4*8.i dont have...
Need some bead blasting and anodizing work done on some bicycle parts.
05.21.2012 15:05
Hey all, first post... I have some aluminum bicycle parts that I would...
What is this stuff? Lead Oxide?
05.21.2012 14:05
Image: http://i53.photobucket.com/albums/g70/dynastypballa/DSC00274.jpg...
what fan and pid is the best
05.21.2012 02:05
Hi. I am new to the forum and going to build a pc oven this week. I have been...
