Plug N' Plate® Brush Plating Kits
The great new way to brush plate small parts
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
4 Simple Steps To Brush Plate Your Small Parts
| 1. Plug In The Adapter | ![]() |
| 2. Clip the Black Lead To The Part | ![]() |
| 3. Soak The Wand With Bandage In the Solution | ![]() |
| 4. Brush The Wand Over The Cleaned Part | ![]() |
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® is perfect for gold plating car emblems. Simply strip the chrome off with Chrome Stripper, then apply the gold. Full instructions are included.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
We do not recommend plating aluminum directly with our Plug N' Plate® kits. Use our Flash Copper Kit with zincate primer first, then you may Plug N' Plate® onto the copper. To plate plastic, or other non-conductive parts, spray with Conductive Paint, dip in Tinning Solution, then tank plate with acid copper, then use a Plug N' Plate® kit.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
Plug N' Plate® Workshop Kit Gift Set
SKU: PNPWKGSRegular Price: $258.30
Special Price: $199.00
Plug N' Plate® Nickel Kit
SKU: PNPNK28$36.99 -
Plug N' Plate® Copper Kit
SKU: PNPCU28$36.99 -
Plug N' Plate® Gold Kit
SKU: PNPGLD38$67.99
Plug N' Plate® Silver Plating Kit
SKU: PNPSLV35$49.99 -
Plug N' Plate® Fast Gold 24K Kit
SKU: PNPFG$399.00 -
Plug N' Plate® FastGold 18K Kit
SKU: PNPFG18$399.00 -
Plug N' Plate® Nickel/Copper Kit
SKU: PNPNC38$49.99
