Everything you need to transform your car or motorcycle rims with one of our exciting Plasti Dip colors. Plasti Dip adds a tough, chip resistant, rubberized coating to your rims, and it just peels right off when you're ready to change colors, or go back to your original rims.
Why spend hundreds of dollars powder coating when you can Plasti Dip?
Kit includes:
- Degreaser
- 4 x 11oz Cans Of Plasti Dip Spray
- Painters Masking Tape
- Microfiber Cloth
The Plasti Dip colors give a Matte finish. If you want a gloss finish, simply select "Gloss" from the Sheen option above, and we'll add a can of Glossifier. Apply this coating after your Plasti Dip has dried.
To coat:
- Remove the rims from the vehicle.
- Wash the rims and then degrease them fully with the supplied cleaner.
- Mask off the tires with the supplied tape.
- Apply 3-4 coats of Plasti Dip to each wheel, slowly building up the thickness.
- Allow to dry
- Apply Glossifier if a gloss finish is desired.
