Pre-thinned with Plasti Dip thinner (a higher quality thinner than toluene or acetone, and the only thinner approved by Plasti Dip), this ready to spray Plasti Dip paint will apply smoothly and easily onto most clean surfaces with a spray gun or Preval Sprayer.
Gives a matte finish. For a gloss finish, apply a coat of Sprayable Glossifier onto the dried Plasti Dip layer.
Not to be used in California. For manufacturer use only. Not for use as an architectural coating
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Anodizing Products (69)
Anodizing Kits (3)
Anodizing Dyes (53)
Chrome Plating Kits (54)
Nickel Plating Kits (57)
Copper Plating Kits (45)
Gold Plating Kits (19)
Gold Tank Plating (10)
Gold Brush Plating (18)
Silver Plating Kits (13)
Chromates (5)
Tin Plating Kits (11)
Metal Strippers (11)
Books and Videos (6)
Plating Crystals (13)
Other Chemicals (47)
Anodes (15)
Plug N' Plate® Kits (27)
Black Oxide Kits (17)
Antiquing Solutions (14)
Buffing/Polishing (432)
Buffing Wheels (80)
Sisal Wheels (6)
Razor Buffs (3)
Scrubber Wheels (2)
Sisal Rope Buffs (1)
Mushroom Buffs (4)
Facer Buffs (3)
Cushion Buffs (3)
Tapered Buff (1)
String Buff (1)
Hourglass Buff (1)
Felt Wheels (5)
Liquid Polishes (4)
Wheel Rake (2)
Buffing Machines (15)
Buffing Adapters (20)
Shaft Extenders (10)
Bench Mandrels (2)
Buffing Kits (24)
Sanding Supplies (5)
Wet/Dry Sandpaper (14)
Abrasive Wheels (28)
Flap Wheels (9)
Cartridge Rolls (8)
Felt Bobs (17)
Diamondite® (22)
Waxes & Polishes (53)
Peek Polish (4)
ShineSeal (2)
Powder Coating (185)
Powder Coating Colors (104)
Metallic Coatings (11)
Candy Top Coats (16)
Powder Coating Ovens (11)
Curing Lamps (3)
Starter Kits (2)
Masking Products (11)
Primers (7)
Restoration Aids (309)
Permatex® Products (103)
Permatex® Cleaners (10)
Permatex® Sealants (11)
Evercoat Products (19)
Glyptal (3)
Metal Etching (2)
Tech-Line Coatings (25)
Lab Metal® (7)
Plasti Dip (45)
Welding Products (7)
Repair Pastes (5)
Cyclone Abrasives (23)
Paints and Coatings (510)
VHT Aerosol Paints (98)
VHT Motor Brite (1)
VHT Quick Coat (13)
VHT Epoxy Paint (3)
VHT Strip Fast (1)
VHT Primecoat (6)
VHT Vinyl Dye (7)
VHT Night Shades (1)
Krylon Fusion (40)
Krylon Engine Paint (11)
Camouflage (45)
Skull Patterns (7)
Metal Patterns (8)
Animal Patterns (9)
Marble & Stone (4)
Illusion Patterns (15)
Accessories (6)
Plasti Dip (47)
Plasti Dip Spray (24)
Gun Metal Bluing (3)
DuraCoat (4)
Shake N' Spray Kits (13)
Shake N' Bake Kits (10)
CamoPack Plus (11)
You have no items to compare.
You have no items in your shopping cart.
Electroplating or etching relief printing plates
06.19.2013 14:06
Hello all, I hope I am in the right place. I am looking for information on...
Composite Curing Oven
06.19.2013 10:06
Hi Guys As this is really the ultimate oven building forum I will try luck...
Trouble anodizing rods ? ? ? ? ?
06.18.2013 22:06
I am having trouble with the rods loosing connection about half way through...
polishing automotive engine parts and diamond plate
06.17.2013 21:06
Hi guys I just bought a 1950 dodge truck and its been rebuilt into a sleeper...
Question about voltage?
06.17.2013 20:06
I just started using the LCD system and have had some good results and...
