Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
Plasti Dip Smoke
You could receive 100 Caswell Gold Rewards Points for writing a review and/or rating this product.
$8.98
Use Your Points:
You will earn 8 Caswell Gold Rewards Points for buying this product
OR
Quick Overview
SKU: PDIP11220
11 oz Aerosol Can
Plasti Dip Smoke
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Plasti Dip Smoke is a special formulation with a translucent, black-gray color. It's distinctive look is great for automotive projects and 1,001 other uses. Plasti Dip Smoke will give your custom car—or any project—a one-of-a-kind look. Unique among Plasti Dip varieties, Plasti Dip Smoke's color changes gradually as more coats are added. After just one or two coats, it's a light, smoky gray. Each additional coat gives Plasti Dip Smoke a darker, deeper hue—from gray to charcoal to black, all with the same distinct smokiness. Like all types of Plasti Dip, Plasti Dip Smoke creates a protective coating that protects against abrasion, corrosion, mild impact, and the elements. It can be applied to nearly any substrate surface, and creates a soft, rubbery, easy-grip surface. Plasti Dip Smoke is available in 11-oz. aerosol cans for fast, convenient application. Just shake it up and spray it on. It's never been easier to add unrivaled style and protection to any DIY project.
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
