Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
Plasti Dip Car Spraying Kit
Be the first to review this product
You could receive 100 Caswell Gold Rewards Points for writing a review and/or rating this product.
Use Your Points:
You will earn 289 Caswell Gold Rewards Points for buying this product
Quick Overview
SKU: PDIP-CKIT
Our Plasti Dip car spraying kit contains all the essentials to coat your standard size automobile (approx 45 sq ft) with Plasti Dip, a high tech, rubberized coating that looks great, is highly durable, inexpensive to apply and peels right off when you want to change colors, or go back to your original finish.
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
* Required Fields
$289.00
Why spend hundreds of dollars powder coating when you can Plasti Dip?
Kit includes:
  • 3 Gallons of pre-thinned, sprayable Plasti Dip
  • 1 Earlex 3500 Self Contained Sprayer
  • 2 x Painters Masking Tape
  • 2 x Shammy Cloths (for pre-coat cleaning)
  • 2 x Microfiber Cloths (for polishing the finished product)
The Plasti Dip colors give a Matte finish. If you want a gloss finish, simply select "Gloss" from the Sheen option above, and we'll add three gallons of pre-thinned Glossifier. Apply this coating after your Plasti Dip has dried.
To coat:
  1. Wash the parts to be painted with soap and water, then clean the part with acetone, lacquer thinner etc to remove all grease and oils.
  2. Dry parts with the shammy cloth.
  3. Mask off the areas you don't want painted with newspaper and the supplied masking tape.
  4. Apply 3-4 coats of Plasti Dip, allowing approx 30 minutes between coats.
  5. Allow to dry (24-48 hours)
  6. Apply Glossifier if a gloss finish is desired.
  7. Polish with the microfiber cloths.
  8. Do not wax the finish, or use a mechanical buffer. Waxing will leave a white residue. Mechanical buffing or pressure washing will remove the coating.
Not to be used in California. For manufacturer use only. Not for use as an architectural coating
Flammable
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
