Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
Plasti Dip Camo Green
Be the first to review this product
You could receive 100 Caswell Gold Rewards Points for writing a review and/or rating this product.
$8.98
Use Your Points:
You will earn 8 Caswell Gold Rewards Points for buying this product
OR
Quick Overview
SKU: PDIP11217
11 oz Aerosol Can
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Plasti Dip Camo is a special collection of Plasti Dip colors designed to match the many shades of nature. Plasti Dip Camo will help keep your hunting and fishing gear, camping equipment, and other outdoor gear inconspicuous when you’re in the wild—or your own backyard. Plasti Dip Camo is available in four unique Earth-tone colors: Green, Tan, Brown, and Black. These specially formulated colors will give your tree stand, duck blind frame, or the stock of your hunting rifle a camouflage look to help you blend in with your surroundings. You can use it to give your boat, trailer, or even your whole car or truck a one-of-a-kind camouflage coating. Any way you use it, Plasti Dip Camo will keep you better hidden from your chosen prey, making it easier to bag The Big One! No matter what color(s) of Plasti Dip Camo you use on your gear, the coated items will gain a soft, rubbery, easy-grip surface. This cushioned grip will surely be welcome when you’re lugging your gear across prime deer hunting country or setting off on a camping trek through the north woods. And, Plasti Dip Camo will give your outdoor gear protection from impact, abrasion, and the elements. If the coating gets damaged or wears out, if you want to give your equipment a thorough deep-cleaning, or if you just want to change the look, Plasti Dip Camo will peel off easily from most surfaces, leaving the item underneath in its original, pre-Dipped condition. Plasti Dip Camo is available in 11-oz. aerosol cans. Just shake it up and spray it on for quick and easy application. There’s no better, simpler way to prepare your gear for the great outdoors!
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
