Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
Plasti Dip Blaze Orange
Be the first to review this product
You could receive 100 Caswell Gold Rewards Points for writing a review and/or rating this product.
$10.29
Use Your Points:
You will earn 10 Caswell Gold Rewards Points for buying this product
OR
Quick Overview
SKU: PDIP11218
11 oz Aerosol Can
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Plasti Dip Blaze is a unique collection of neon Plasti Dip colors that deliver eye-catching looks for any application. Use Plasti Dip Blaze anywhere you need bright, easy to see colors—you can use it to improve visibility for safety concerns, to add can’t-miss color to frequently misplaced items, or for a one-of-a-kind look on almost anything, from automotive projects to outdoor gear to arts and crafts. Plasti Dip Blaze is available in two eye-catching colors, Blaze Blue and Blaze Orange, with more colors in the works for release in the near future. The Blaze collection applies quickly and easily to nearly any substrate material, and creates a protective coating to shield against abrasion, corrosion, mild impact, and the elements. Plasti Dip Blaze also creates a soft, easy-grip surface that helps prevent skidding and slipping. If the coating gets damaged or wears out, or if you decide to change the look of your Plasti Dipped items, cured Plasti Dip Blaze will peel off easily from most surfaces. It leaves the material underneath in its original, pre-Dipped condition. All colors of Plasti Dip Blaze are available in convenient 11-oz. aerosol cans. Just shake it up and spray it on to give any DIY project a vivid, attention-grabbing look. For the brightest possible colors, it’s best to apply Plasti Dip Blaze over a white base, preferably white Plasti Dip for optimum adhesion.
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
