Photo-Graphics Water Transfer Imaging Kits
Water transfer imaging, also called curve coating printing, or hydrographics, is a way to transfer an image to a 3D surface. This overcomes problems faced by offset printing, such as, the image not printing in hard to reach areas, or the higher expense of equipment.
The water transfer imaging process can be applied to the surface of materials such as metals, wood, plastic, stone, bakelite, ceramic, etc
MyDipkit is a do it yourself version of the commercial process known as water transfer imaging. This allows you to process parts on a small scale in your home. The kit contains the printed film, chemicals, and basic supplies needed for processing parts at home.
You will need to provide a container for dipping the items in. You will also need to supply warm water, and the item to be decorated.
With these kits you will be able to camo dip your own items. This is the same process that gun and ATV manufacturers use to print camo patterns on their guns and ATVs.
This is the same process that automotive manufacturers use to print wood grain patterns on plastic interior pieces.
This process can be done on any part that can be safely submerged under water.
- The basics steps are:
- Clean and prep the part
- Base coat the part
- Dip the part
- Clear coat the part
The myDipkit water transfer imaging kit comes standard with the following items:
- 1 x 4 oz aerosol can of activator
- 1 x Mask 1 x 4 oz Aerosol can of primer
- 1 x Pair of latex gloves
- 1 x 4 oz Aerosol can of base coat paint
- 1 x 3" x 4" scuff pad
- 1 x 4 oz Aerosol can of clear top coat
- 1 sq. meter of Film (pattern based on which kit you choose)
- 1 x Detailed instructions for the dipping process
Image Country ™ Camouflage Havoc Plus MyDipKit
SKU: DK-574$99.00 -
TimberTec Green MyDIpKit
SKU: DK-210$99.00 -
TimberTec Brown MyDIpKit
SKU: DK-200$99.00 -
Timber's Edge Camo Timber's Edge XD MyDIpKit
SKU: DK-442$99.00
Thriving Forest Camouflage MyDIpKit
SKU: DK-452$99.00 -
Team Hard © MorningWood Camouflage MyDIpKit
SKU: DK-145$99.00 -
Sticks 'N Limbs Winter Camouflage MyDIpKit
SKU: DK-5003$99.00 -
Sticks 'N Limbs Summer Camouflage MyDIpKit
SKU: DK-5013$99.00
