The Spray Station 3500 is the tool homeowners and do-it-yourselfers need for multiple tasks requiring a fine finish. This multi-purpose sprayer handles a variety of materials and is ideal for a wide range of projects. No air compressor or hoses required. Just fill with your coating and spray.
The ideal unit for spraying our thinned Plasti Dip Coatings and lacquers, varnishes, sealers, urethanes, acrylics and almost any liquid coating.
The NEW expert spray gun provides the user with maximum control and minimal overspray. The gun's outstanding features include a fast, three-pattern changing system, a thumb-control paint-flow dial, a one-quart wide-mouth paint container, an angled pick-up tube for overhead or downward spraying and front-loading needles that make changing needles fast and clean up a breeze.
With the Spray Station 3500, you’ll remain in constant control, achieve a great finish, make your materials go further and clean up faster than with a brush or roller.
The 3500 can be used indoors to maintain walls, ceilings, trim work, cabinets and furniture. Take the 3500 outdoors to spray fences, decking, shutters, garden furniture, sheds and cabins. Your arts, crafts and woodworking projects will have a professional quality and a mirror-like finish when you use the Spray Station 3500.
Technical Specs
- 500-watt motor turbine spray volume control
- stain/latex tip
- three-spray pattern adjustor
- one-quart wide-mouth paint container
- nine-foot hose
- on-board hose storage
- on-board spray gun storage
- viscosity cup
- angled pick-up tube
- front-loading tip/needle
- seven-foot power cord
- 43 CFM
- 2 PSI
- DIN/sec = 160
- Made In The United Kingdom
