Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
HUGE LIQUIDATION SALE
50% OFF
All VHT, Dupli-Color, Krylon, Permatex, Plasti-Dip and Powder Coating Colors
Order Now While Supplies Last
* - While Supplies Last. Limited Stocks available. We are not able to apply to items not in stock. No backorders.
Caswell Sealer - 4 fl oz
$9.99
You will earn 9 Caswell Gold Rewards Points for buying this product
OR
Quick Overview
SKU: CSEAL4
Use as a primer over porous items like baby shoes, leaves, flowers etc. Caswell Sealer is also highly effective as a corrosion resistant coating over most metals, including Black Oxide coatings, Silver Plate, Gold Plate, Copy Chrome and antiqued copper or brass.
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Caswell Sealer Concentrate
Caswell Sealer is a fast drying coating that penetrates porous materials such as cloth, leather, plaster of paris, concrete etc. rendering it non-porous.
The concentrate can be used as is, or thinned with an equal amount of water. The part is then totally immersed in the solution for 15-30 minutes, then allowed to drip dry. A second application several hours later renders the surface completely smooth and non-porous.
To make the part conductive the part is then sprayed with Copper Conductive Paint or SilvaSpray. Finally, the part can be plated with bright acid copper.
Ideal for plating baby shoes, bone, plants, cloth and other porous items.
Caswell Sealer is also highly effective as a corrosion resistant coating over most metals, including Black Oxide coatings, Silver Plate, Gold Plate, Copy Chrome and antiqued copper or brass. Thickness: 0.09mm.
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
