Discover this revolutionary paint for plastic - Fusion. This top-selling paint is the first of its kind that bonds directly to most plastics. Turn a treasured toy into something new again. Get many more years of enjoyment out of your outdoor patio furniture. And don't waste that waste paper basket - simply give it a new coat of paint.
• No sanding, no priming, no fuss
• Dries in 15 minutes or less
• Features the EZ Touch Fan™ Spray Nozzle
Recommended Surfaces:
- Ceramic/Plaster
- Glass
- Hard Vinyl
- Metal
- Paper
- Papier Mache
- Plastic
- Wicker
- Wood
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Anodizing Products (69)
Anodizing Kits (3)
Anodizing Dyes (53)
Chrome Plating Kits (54)
Nickel Plating Kits (57)
Copper Plating Kits (45)
Gold Plating Kits (19)
Gold Tank Plating (10)
Gold Brush Plating (18)
Silver Plating Kits (13)
Chromates (5)
Tin Plating Kits (11)
Metal Strippers (11)
Books and Videos (6)
Plating Crystals (13)
Other Chemicals (47)
Anodes (15)
Plug N' Plate® Kits (27)
Black Oxide Kits (17)
Antiquing Solutions (14)
Buffing/Polishing (439)
Buffing Wheels (80)
Sisal Wheels (6)
Razor Buffs (3)
Scrubber Wheels (2)
Sisal Rope Buffs (1)
Mushroom Buffs (4)
Facer Buffs (3)
Cushion Buffs (3)
Tapered Buff (1)
String Buff (1)
Hourglass Buff (1)
Felt Wheels (5)
Liquid Polishes (4)
Wheel Rake (2)
Buffing Machines (15)
Buffing Adapters (20)
Shaft Extenders (10)
Bench Mandrels (2)
Buffing Kits (24)
Sanding Supplies (5)
Wet/Dry Sandpaper (14)
Abrasive Wheels (28)
Flap Wheels (9)
Cartridge Rolls (8)
Felt Bobs (17)
Diamondite® (24)
Waxes & Polishes (53)
Peek Polish (4)
ShineSeal (2)
Powder Coating (187)
Powder Coating Colors (106)
Metallic Coatings (11)
Candy Top Coats (16)
Powder Coating Ovens (11)
Curing Lamps (3)
Starter Kits (2)
Masking Products (11)
Primers (7)
Restoration Aids (309)
Permatex® Products (103)
Permatex® Cleaners (10)
Permatex® Sealants (11)
Evercoat Products (19)
Glyptal (3)
Metal Etching (2)
Tech-Line Coatings (25)
Lab Metal® (7)
Plasti Dip (45)
Welding Products (7)
Repair Pastes (5)
Cyclone Abrasives (23)
Paints and Coatings (515)
VHT Aerosol Paints (99)
VHT Motor Brite (1)
VHT Quick Coat (13)
VHT Epoxy Paint (3)
VHT Strip Fast (1)
VHT Primecoat (6)
VHT Vinyl Dye (7)
VHT Night Shades (1)
Krylon Fusion (40)
Krylon Engine Paint (12)
Camouflage (45)
Skull Patterns (8)
Metal Patterns (8)
Animal Patterns (9)
Marble & Stone (4)
Illusion Patterns (15)
Accessories (6)
Plasti Dip (47)
Plasti Dip Spray (24)
Gun Metal Bluing (3)
DuraCoat (4)
Shake N' Spray Kits (13)
Shake N' Bake Kits (10)
CamoPack Plus (11)
You have no items to compare.
You have no items in your shopping cart.
Cathode to Anode ratio
05.20.2013 15:05
I’ve read that you should have at least a ratio of 1:1 cathode to anode for...
Buying a gun, which do you recommend? Ez50 or hyper smooth 2.0 ?
05.19.2013 15:05
Bought a wai/craftsman style but sent it back, felt like it was gonna break...
Various Tank Liquid Levels
05.18.2013 16:05
Folks, I was wondering if the is some kind of “rule of thumb” for the amount...
Spot welder recommendations?
05.16.2013 19:05
So, I've noticed some mention of a "sput welder" in the forums, that seems to...
Circulation pump plus aerator
05.16.2013 14:05
If I use a little gaint HC type cirulation pump in my ano bath do I still...
