Quick view Caswell sku: LG580603 LITTLE GIANT BORON NITRIDE PUMP MSRP: Now: $520.29 Add to Cart Compare Quick view Caswell sku: MCB24 Mist Control Balls - 2 sq ft MSRP: Now: $44.54 Add to Cart Compare Quick view Caswell sku: MCB15 Mist Control Balls 1 sq foot MSRP: Now: $23.64 Add to Cart Compare Quick view Caswell sku: PHKIT PH Buffer Solution Kit (One Each 4, 7 & 10 Buffer Solutions) 4 oz MSRP: Now: $13.19 Add to Cart Compare Quick view Caswell sku: PLTNK5 PLATING TANK W/LID- 6 GAL MSRP: Now: $17.59 Add to Cart Compare Quick view Caswell sku: PLTNK1G PLATING TANK W/LID - 1 GAL MSRP: Now: $6.04 Add to Cart Compare Quick view Caswell sku: PLTNK35 PLATING TANK W/LID - 3.5 GAL MSRP: Now: $14.84 Add to Cart Compare Quick view Caswell sku: PLTNK2G PLATING TANK W/LID- 2 GAL MSRP: Now: $8.79 Add to Cart Compare Quick view Preval sku: PREPWR PREVAL POWER UNIT MSRP: Now: $10.99 Add to Cart Compare Quick view Preval sku: PREV9 PREVAL SPRAY GUN MSRP: Now: $13.19 Add to Cart Compare Quick view Preval sku: PREVFAN Preval vFan Portable Airbrush System MSRP: Now: $277.19 Add to Cart Compare Quick view Aquatic Life sku: RO1 Reverse Osmosis System - 3 Stage 50GPD MSRP: Now: $139.00 Add to Cart Compare Quick view Caswell sku: POP3 STEEL PLATE OUT PAD MSRP: Now: $4.39 Add to Cart Compare Quick view Caswell sku: UC1P ULTRASONIC JEWELRY CLEANER - 1 PINT MSRP: Now: $19.79 Add to Cart Compare Quick view LITTLE GIANT BORON NITRIDE PUMP Designed for use with our Boron Nitride Electroless Kits, or for pumping any high temperature (up to 200°F) liquid. Brand Name: Little Giant 580603 Magnetic Drive Pump Power Rating 1/30 HP Voltage @ 60 Hz 115V AC Power Cord Length: 6 foot ... MSRP: Now: $520.29 Add to Cart Compare Quick view Mist Control Balls - 2 sq ft Due to the high current usage during chrome plating, a mist of acid is produced from the tank. This can become a nuisance due to the corrosive nature of the product and its yellow stain. The Complete Plating Manual shows how to control... MSRP: Now: $44.54 Add to Cart Compare Quick view Mist Control Balls 1 sq foot Due to the high current usage during chrome plating, a mist of acid is produced from the tank. This can become a nuisance due to the corrosive nature of the product and its yellow stain. The Complete Plating Manual shows how to control... MSRP: Now: $23.64 Add to Cart Compare Quick view PH Buffer Solution Kit (One Each 4, 7 & 10 Buffer Solutions) 4 oz DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool water. The unit is splash-proof, and has one point... MSRP: Now: $13.19 Add to Cart Compare Quick view PLATING TANK W/LID- 6 GAL Plating Tank, White with Lid 6 Gal MSRP: Now: $17.59 Add to Cart Compare Quick view PLATING TANK W/LID - 1 GAL Plating Tank, White with Lid 1 Gal MSRP: Now: $6.04 Add to Cart Compare Quick view PLATING TANK W/LID - 3.5 GAL Plating Tank, White with Lid 3.5 Gal MSRP: Now: $14.84 Add to Cart Compare Quick view PLATING TANK W/LID- 2 GAL Plating Tank, White with Lid 2 Gal MSRP: Now: $8.79 Add to Cart Compare Quick view PREVAL POWER UNIT Refill for the Preval Spray System. Does not include glass bottle. MSRP: Now: $10.99 Add to Cart Compare Quick view PREVAL SPRAY GUN Use this spray system to spray Copper Condutive Paint, Silvaspray, or any lacquer based paints. System comes complete with glass jar, sprayer and lid. Refill sprayers are available. MSRP: Now: $13.19 Add to Cart Compare Quick view Preval vFan Portable Airbrush System The vFan Portable Airbrush is an all-in-one touch-up system for precision painting, surface prep, touch-ups and curing anywhere and anytime. Our siphon-fed, dual-action stainless steel and brass vFan airbrush delivers professional results with a silent... MSRP: Now: $277.19 Add to Cart Compare Quick view Reverse Osmosis System - 3 Stage 50GPD Make your own Reverse Osmosis water for mixing plating and anodizing chemicals. This unit will produce up to 50 gallons per day. Includes faucet connector that allows easy connection to a garden hose. Three stage filtering system removes all... MSRP: Now: $139.00 Add to Cart Compare Quick view STEEL PLATE OUT PAD Steel Plate Out Pad MSRP: Now: $4.39 Add to Cart Compare Quick view ULTRASONIC JEWELRY CLEANER - 1 PINT Provides a sparkling, like new clean to jewelry when used with an ultrasonic cleaner. Pour in enough solution to cover the items. If the cleaner has a heater function, turn it on for best results. Run the cleaner for 3 minutes. Rinse in tap water after... MSRP: Now: $19.79 Add to Cart Compare Previous 1 2 Previous 1 2 Compare Selected × OK
