Caswell Inc   7696 Route 31
Lyons NY 14489 USA
Orders: Toll Free 1-855-CASWELL
Product Selection Help
Order By Phone: 9am-4pm ET
1-855-CASWELL
Buy Caswell Gas Tank Sealer Here
Welcome To Caswell
Black Satin Header Coating 4 oz
You could receive 100 Caswell Gold Rewards Points for writing a review and/or rating this product.
$19.95
Use Your Points:
You will earn 19 Caswell Gold Rewards Points for buying this product
OR
Quick Overview
SKU: TL1004
Double click on above image to view full picture
Zoom Out
Zoom In
More Views
Exhaust System Coatings
TECH LINE COATINGS makes available a full range of exhaust system coatings that can be applied at home. TECH LINE COATINGS offers the most technologically advanced coatings on the market. These coatings include the most popular type of coating in use today, a metallic ceramic. These coatings are the same products being applied by professional coating shops and give the individual the opportunity to benefit from this advanced technology at both a cost and time savings.
Coverage
(APPROXIMATE) ALL EXHAUST SYSTEM COATINGS
SMALL V8 HEADERS AND CAST IRON MANIFOLDS 4 OZ. PER PAIR
MEDIUM V8 HEADERS 6 TO 8 OZ. PER PAIR
LARGE V8 HEADERS 10 TO 12 OZ. PER PAIR
Black Satin (BHK)
  • Black Satin is the most advanced exhaust system coating available
  • Withstands 2000f temperatures
  • Easy to apply ceramic reinforced coating designed for high temperature applications
  • Reduces underhood temperatures, reduces exhaust manifold surface temperatures
  • Improve exhaust gas velocity, increase H.P.
  • Air drying, requires no baking
  • Coverage: See above
APPLICATION: Sandblast all parts with 120 grit aluminum oxide. DO NOT USE GLASSBEAD. Clean metal using conventional cleaning methods, with acetone, lacquer thinner or other similar non-petroleum based solvent.When the surface is clean and dry, apply a thin even layer of coating using an airbrush, detail touch-up gun or other spray equipment that allows for application of a thin film of approximately .001" to .0015". Avoid excessive build-up of material as this can lead to loss of adhesion. DO NOT APPLY A SECOND COAT AFTER THE COATING DRIES. The coating will air dry to the touch in a few minutes. Install on vehicle, as the coating will cure with exaust heat.
CAUTION: Excessive exhaust heat due to a poorly tuned engine can damage the coating during the cure period. Do not install on a new engine untill all adjustments have been made to the valves, timing and jetting. Allow the engine to idle, or drive gently for approximately 30 minutes or until no vapor/smoke is given off by the coating. MAINTAIN adequate ventilation during this process.
Full cure occurs at 750F Especially effective on Turbo housings, head pipe and down tube.
Product Tags
Use spaces to separate tags. Use single quotes (') for phrases.
Earn 5 Caswell Gold Rewards Points for each approved tag you make.
